Panel Menu & floating Layer in Full screen Mode !
amir2314
Post by amir2314 » Mon Aug 07, 2017 8:08 pm
Hello dear pablo , i don't know that is the bug or not?!!!
Floating layer in full screen floating mode not matched with panel menu together !!!!
this is the wbs project link
https://ufile.io/o3sj6
floating layer can't show when panel menu added to project ! when i delete the panel menu floating layer in full screen mode running right!
tested it with all page alignment properties !
i Need Your Help , Thank You Very Much - AMIR REZAEYAN
Re: Panel Menu & floating Layer in Full screen Mode !
Post by Pablo » Mon Aug 07, 2017 9:26 pm
This is expected behavior.
The panel menu 'wraps' around the body container of the page, so it can push the content. If the page alignment is set to 100% then there is no body container.
So these features cannot be used together, they conflict each other's behavior.
Users browsing this forum: No registered users and 4 guests
