Masterobject - Duplicate - error
amir2314
Post by amir2314 » Wed Aug 09, 2017 6:00 pm
Hello Dear Pablo - i have a problem , some time's i need to have the same master object in my page, but when i duplicate Master Objects Software show me the warning + you cannot use the same master page more than once per page !!!! but i need this Ability To SAVING MY TIME !
another Problem is : when i group my objects for example i have 5 layer and in each layer's i have some object's when i group them to change the position , object position lost and can't move right ! (boooom) !!!
Re: Masterobject - Duplicate - error
Post by Pablo » Wed Aug 09, 2017 7:07 pm
I'm sorry but what you want is not possible. HTML does not allow duplicated IDs. This will corrupt the DOM and objects can no longer be addressed by CSS and JavaScript.
This is not specific for WWB, it's a HTML rule.
Why are you grouping layers? A group in basically a 'saved' selection and it is only useful for absolute positioned objects, not for floating objects.
