long site load on opening
Aibek
Post by Aibek » Wed Jun 13, 2018 7:09 am
After successful publication, when you open the site for a long time does not open.
I do not know what the problem is. after the next update of the site, the site began to load for a long time. can someone deal with such a problem? tell me please what can be the reasons and how to fix it? link to the site www.adoors.kz
Re: long site load on opening
Post by Pablo » Wed Jun 13, 2018 7:53 am
Please remove all custom code (third party scripts) and then try again.
Aibek
Post by Aibek » Fri Jun 15, 2018 3:48 am
I tried, unsuccessfully. All the same
Post by BaconFries » Fri Jun 15, 2018 4:04 am
I am sorry only you yourself can remove all manually added code the way you added it.
Examples of manually added by using the HTML Object.
Html4wheather
Html3Liveinternet
Html5kurs
Html6googlanalitic
Html8yansexmetrik
Html10Livetex
Post by Pablo » Fri Jun 15, 2018 5:59 am
There is still third party code on the page.
Please remove all scripts, until you have found the one that is slowing down the page.
Aibek
Post by Aibek » Fri Jun 15, 2018 12:03 pm
Everything worked out. Thank you very much
