Can't publish to GoDaddy
thebizman
Post by thebizman » Fri Jun 29, 2018 5:29 pm
When trying to post or test, I get the 550 error message. Here is the log. Any ideas?
I thought that WWB created the file.
*** START OF PUBLISH ***
Scanning publish folder...
Found 74 file(s).
Status: Initializing FTP connection...
Status: Checking host...
Status: Host was successfully parsed.
Status: Connecting to 107.180.0.195...
Status: Using PASV mode.
Response: 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
Response: 220-You are user number 4 of 500 allowed.
Response: 220-Local time is now 10:16. Server port: 21.
Response: 220-This is a private system - No anonymous login
Response: 220 You will be disconnected after 15 minutes of inactivity.
Command: USER ug5fuakjxq56
Response: 331 User ug5fuakjxq56 OK. Password required
Command: PASS *****
Response: 230-Your bandwidth usage is restricted
Response: 230 OK. Current restricted directory is /
Command: SYST
Response: 215 UNIX Type: L8
Command: SITE HELP
Response: 214-The following SITE commands are recognized
Response: ALIAS
Response: CHMOD
Response: IDLE
Response: UTIME
Response: 214 Pure-FTPd - http://pureftpd.org/
Status: Succesfully connected.
Command: PWD
Response: 257 "/" is your current location
Status: Current directory is '/'
Status: Setting remote folder to tallhat.net...
Command: CWD tallhat.net
Response: 550 Can't change directory to tallhat.net: No such file or directory
Error: 550 Can't change directory to tallhat.net: No such file or directory
Status: Closing FTP connection...
Command: QUIT
Response: 221-Goodbye. You uploaded 0 and downloaded 0 kbytes.
Response: Connection with server closed.
Removing temporary files...
Publish failed!
*** END OF PUBLISH ***
Re: Can't publish to GoDaddy
Post by Pablo » Fri Jun 29, 2018 6:02 pm
Maybe your host has switched to Secure FTP?
http://wysiwygwebbuilder.com/secureftp.html
Post by zinc » Mon Jul 02, 2018 11:08 am
I have client with GoDaddy and no issues uploading. However I highly recommend you purchase this extension. This is a MUST if you want to publish from WWB directly and it works like a charm!
http://www.wysiwygwebbuilder.com/secureftp.html
