No preview no publish
RNuesslein
Post by RNuesslein » Mon Jul 23, 2018 12:19 pm
Hello
I begann to renew our page with a new file using the snowworld template
When I want to preview the page the "Generate HTML output" windows opens with the text "generate 'index.html'..." in it.
I waited for 5 or 10 minutes, but actually nothing happens (So far, index.html, is the only page)
When I press the "Publish-botton", nothing happens, no windows opens
Maybe something happend here: When I started the new project, I opend WYSIWYG Webbuilder a second time, so I could copy and paste text from the old project to the new one.
I work with the newest version 14.1.0
Here is the file
https://www.dropbox.com/l/scl/AABJxlg8W ... qqRG4PsWqk
Thanks for all answers
Blessings!
Re: No preview no publish
Post by Pablo » Mon Jul 23, 2018 12:30 pm
Maybe you have set the to 'do not publish'?
or maybe your system does not have a default browser?
Or maybe your virus scanner or ad blocker accidentally triggers?
I was not able to download your project because it requires to create an account.
RNuesslein
Post by RNuesslein » Tue Jul 24, 2018 9:02 am
Thanks for your answaer, Pablo
I did everything, it still does not work.
I uploaded the files here:
http://www.agape-salzburg.org/wysiwyg.html
Post by Pablo » Tue Jul 24, 2018 9:34 am
I did not find any problems previewing or publishing the project you have shared. It works for me.
However, I have noticed you have added several extensions, which are very old and were not designed to be used in layout grids.
Does it work when you remove these extensions?
