WYSIWYG 11 BUILT IN FTP PUBLISHED ERROR
eddielabiste
Post by eddielabiste » Tue Aug 14, 2018 9:27 am
I HAVE PURCHASED MY WYSIWYG 11, LAST NOVEMBER 11, 2016. SINCE EARLIER THIS YEAR OF 2018, I HAVE BEEN ENCOUNTERING A PROBLEM WITH REGARDS OF PUBLISHING FTP AND THE ERROR IS THIS; Internet Exception Error 12111 Details: The FTP session was terminated.
ALL POSSIBLE SOLUTIONS WERE DONE ALREADY SUCH AS GETTING NEW BIGGER DISK SPACE, SHUT DOWN ANTI VIRUS WHEN PUBLISHING & ALLOWING WINDOWS FIREWALL THE WYSIWYG PROGRAM TO RUN. ANY SUGGESTION PLEASE...THANK YOU!
Re: WYSIWYG 11 BUILT IN FTP PUBLISHED ERROR
Post by Pablo » Tue Aug 14, 2018 9:54 am
Did it previously work?
If yes, then did you change something?
If not then this is most likely a server related issue.
See also the FAQ:
viewtopic.php?f=10&t=36493
Please do not shout.
Post by BaconFries » Tue Aug 14, 2018 10:40 am
Yes please don't shout (using uppercase) as it is rude! One possible reason is that your host/server no longer supports FTP and requires you to now use SFTP you will need to contact them and ask if this is the case. If the answer is yes then you will need the following extension (Paid)*
https://www.wysiwygwebbuilder.com/secureftp.html
