Images show when published on server but not in Preview
Rick47
Post by Rick47 » Sat Aug 18, 2018 11:22 am
I managed to get the html to look at the images in a subfolder under the html folder when running on my server - and all works fine.
I did this my changing the values under Tools>Options>Publish>Target Folder for File Types. (as you suggested in another thread)
I changed the folder name from 'images' to '/images'. This points the html to my subfolder images under the html folder on the sever.
All works well at runtime from the server. Images are shown.
However when I now use the Preview option in Web Builder 14 on my local PC during development, the images do not now show.
I am having to change the folder name back to 'images' while in development and then change it back to '/images' before I publish.
Is this a bug or is there another setting I am missing?
Re: Images show when published on server but not in Preview
Post by Pablo » Sat Aug 18, 2018 11:31 am
This is not a bug. The software does not care what the folder name is, it's the browser that may have a problem with it.
I do not think you should use slash in the folder name. It works without a slash for all other users.
