publishing
kenknotts
publishing
Post by kenknotts »
I have a page of newsletters to publish. I select publish changed file only but it republishes many files that have not been changed and the result is it times out. I would like to set those files as not changed so it will not publish them every time. How do I do that.
Ken
Re: publishing
To be able to help you, I need more information,.
What do you pages look like, which objects did you use?
What exactly did you edit?
kenknotts
Re: publishing
Post by kenknotts »
Here is the link to the page - http://www.fwthunderbirds.org/Newsletters.html
I added the link to the September file. When I publish, I select to upload changed files and it starts uploading files that have not been changed at all. Only the September file has been added.
Thank you for you assistance.
Ken
Re: publishing
The application does not keep track of external files and whether or not they have been changed. This option only applies to internal changes.
So, all linked files (pdfs) will be published.
It is usually better to upload larger files manually to the server and use absolute links.
Note that file names of your PDFs are invalid and may causes issues now or in the future.
See this related FAQ:
viewtopic.php?f=10&t=131
