Image showing from breakpoint
papsy
Post by papsy »
www.angelesclassified.com/spontini
Have a map on breakpoint 640 showing on desktop even though visibility is off!
doesnt show on 360 breakpoint.
Can you advise.
thank you
Re: Image showing from breakpoint
I cannot see what you have done based on the HTML code only.
To be able to help you , I need a (stripped) copy of the project file.
See this related FAQ:
papsy
Post by papsy »
I think I found the cause, it seems to be an event, deleted it and the visible image has disappeared.
Papsy
