Issue with Layout Grid scaling
antony
Post by antony »
Hello, as I migrated a project built with WWB14 to WWB15, I started having problems with the scaling of Cyrillic script that has been added with WWB15. As you can see in the picture, the text is bumping into the other text instead of going to the next line.
Screenshot- https://rise-bg.com/screenshot2.jpg
Re: Issue with Layout Grid scaling
Maybe the size of the text object is fixed?
To be able to help you, I need a demo project so I can see all the settings.
Related FAQ:
antony
Post by antony »
Please set the output format of the text object to 'Default', then it will work just like in WWB14.
antony
Post by antony »
Thank you very much for your help!
