Just recently I have been updating some of my pages since the last upgrade and now I found the text alignment is acting strangely, can't explain it you need to check it out.
https://www.gatesplus.com.au/CATSliding.php yet some text is ok, I have been checking the tick box in text for "ënable responsive fonts".
The fonts are Arial or Verdana. At the same time some images also are not showing really strange have not change the publishing Parameters.
Text alignment.
http://www.wysiwygwebbuilder.com/publish.html
http://www.wysiwygwebbuilder.com/preview.html
Frequently Asked Questions about Publishing
Re: Text alignment.
Did you re-publish all files, so the server have all the latest files?
Where exactly do I need to lo to see the problem?
What is the page suppose to look like?
Re: Text alignment.
I just re-published using Ver 14.3.3 from another computer I have it now looking OK all the text is line up look the way it should, I will send you screen shots later. I am at work at this time.
Re: Text alignment.
I think it's ok now, Firefox for some reason is not showing images with a image name with a space in the name e.g Wheel-hub.jpg I changed it to Wheelhub.jpg and now it OK.
Re: Text alignment.
Please see this related FAQ:
viewtopic.php?f=10&t=131
