DBTS Form Processor does not appear in the extensions list
Issues related to forms.
janim
Post by janim » Sun Mar 11, 2018 7:03 pm
I had a processor installed, but it did not appear on the list.
After the reinstallation, the situation is the same. Extension manager indicates that it is installed
Re: DBTS Form Processor does not appear in the extensions list
Post by Pablo » Sun Mar 11, 2018 7:06 pm
Maybe you have customized the toolbox, so it is hidden?
janim
Post by janim » Sun Mar 11, 2018 7:11 pm
Аll other extensions are visible - DBTS CSV Delete Record; Edit Record ....... sorted alphabetically.
janim
Post by janim » Sun Mar 11, 2018 7:13 pm
Еrror is mine, I apologize very much !
