reCAPTCHA V2 Array Error
Issues related to forms.
sstepun
Re: reCAPTCHA V2 Array Error
Post by sstepun » Thu Aug 16, 2018 7:09 pm
This has never worked from day one. I know the keys are correct. I have looked at the code and the keys are correct there also.
Post by Pablo » Thu Aug 16, 2018 8:09 pm
Are you using the most recent version of the software and the extension?
Older versions of the extension did not support case sensitive servers. This has been solved several months ago.
h3rnan
Post by h3rnan » Sat Nov 24, 2018 1:02 am
GeorgeR wrote:
Sat May 05, 2018 6:59 pm
I created a simple contact form using the built in PHP form processor script and it works works well, no issues at at. Then I decided to add reCAPTCHA V2 to add some spam protection, but not having much success with that. I donwloaded and installed the extension and added reCAPTCHA V2 to my existing form script which was previouly working. Copy and pasted the Site and Secret keys from Google and published the form to the server along with the reCAPTCHA folder. The form (which is php) and reCAPTCHA folders do appear on the server. The form page loads ok in the browser, and the green check mark (not a robot) appears when the box is clicked. However, when the form is sent an error code appears: The reCAPTCHA code is incorrect. Please try again. Error: Array. I had thought that, perhaps, I had not entered the Site and Secret key codes properly, but I repeated that process again several times and repulbished, with the same result. Any idea what might be going on?
Have you solved the issue? Same here..
Hernán Pena
Web & Graphic Designer / System & Network Administrator
Post by Pablo » Sat Nov 24, 2018 7:30 am
Does your host support PHP 5.6 or newer?
Did you add the catpcha extension to the form?
h3rnan
Post by h3rnan » Sat Nov 24, 2018 11:32 am
No, Hosting says 5.5.2.
Yes, into layout grid.
Hernán Pena
Post by Pablo » Sat Nov 24, 2018 1:07 pm
In that case recaptcha 2 probably will not work.
h3rnan
Post by h3rnan » Sat Nov 24, 2018 1:11 pm
Yes, I'm already working on alternatives.
Thank you.
Hernán Pena
jors
Post by jors » Fri Dec 14, 2018 3:44 pm
I struggle for quite some time with exactly the same error. Did anyone managed to find a solution?
Post by Pablo » Fri Dec 14, 2018 4:03 pm
Did you check the PHP version on the server?
jors
Post by jors » Fri Dec 14, 2018 4:10 pm
Yes I did PHP version 7.2
Post by Pablo » Fri Dec 14, 2018 4:16 pm
In that case it should work without any issues.
jors
Post by jors » Fri Dec 14, 2018 4:27 pm
Here is the contact page with the issue https://yourhearing.co.za/page1.php if it would help to assist.
Would it help and be save to upload files recaptcha folder to forum?
Post by Pablo » Fri Dec 14, 2018 4:31 pm
The recaptcha seems to be displayed correctly.
Note that I cannot provide support on the underlying functionality. This is a third party script.
