Adding variables.
Issues related to forms.
MartinPorter
Adding variables.
Post by MartinPorter » Thu Nov 01, 2018 8:20 pm
Hi Everyone.
Within Advanced Form Processor Properties, Auto Repsponder within the Message box
is there a way that a variable can be used? eg if used the name of the outgoing user?
it would just put the icing on the cake :) if you could.
thanks & regards
Martin....
Thanks & regards
Martin....
Re: Adding variables.
Post by Pablo » Thu Nov 01, 2018 9:11 pm
With a little bit of creativity you can use PHP variables by using quotes.
For example:
This is a variable ' . $variable . ' in a message
This requires some knowledge of PHP.
MartinPorter
Post by MartinPorter » Thu Nov 01, 2018 9:36 pm
For example:
thanks Pablo - I'll have to look around for a masterclass on PHP :o not my best subject :oops:
thanks & regards
Martin...
Thanks & regards
Martin....
