Combobox Multiple Selection
Issues related to forms.
Williams
Post by Williams » Mon Dec 31, 2018 6:51 pm
Hello everybody,
Actually i'm trying to create a form with Combo box with Multiple Selection. including (A,B and C). when i select " A Plus C". it only gives A..
Am i missing something!!!
Thank you.
Re: Combobox Multiple Selection
Post by Pablo » Mon Dec 31, 2018 6:54 pm
This is from the help:
It's important to note that the element name must be in the form name[] for multiple selects! This way you'll receive the selected values in an array (this is a PHP feature).
Williams
Post by Williams » Mon Dec 31, 2018 7:01 pm
Do you mean to be [A] and [C] instead of A and C!!
Post by Pablo » Mon Dec 31, 2018 7:31 pm
I'm sorry, I do not know what you mean by [A] and [C].
I am referring to the name of the combo-box.
if this does not answer your question then please try to be more specific (include the URL of the page, your settings etc.)
Post by BaconFries » Mon Dec 31, 2018 9:23 pm
Did you include brackets in the combobox name? Also please see the Help for more information.
Williams
Post by Williams » Tue Jan 01, 2019 1:12 am
Do you mean to re-name the compo box name! lets say my compo box named William. so i have to re-name it to [William].
Am i right!! If yes so i already did that. and Unfortunately that doesn't work with me.
Thank you BaconFries for your reply. My answer yes Based on Pablo response.
Post by BaconFries » Tue Jan 01, 2019 3:48 am
No, at this moment I am not at PC, and as it is New Year and have had one or two 🥃🥃🥃 try "William[ ]" without the quotes ....
Post by Pablo » Tue Jan 01, 2019 9:34 am
Not [William], but William[]
Williams
Post by Williams » Tue Jan 01, 2019 10:08 am
You're right Pablo. It works that way.
Hopefully you give an example in the Help file. i think that would be very useful.
Thank you alexmasss , BaconFries and Pablo as usual. you're the clue of this forum.. 8)
Happy New year All.
Dougie13
Post by Dougie13 » Sat Feb 29, 2020 10:33 pm
Hi all,
Should the combobox multiple choices (array) work with the mysqlconnector ?
I am trying to get a simple multiple selection to be added to a mysql field (Blob, Json) to add a simple array of 2-3 names selected from list.
I have named the element testname[], and also tried the Object ID in the mysql connector as both testname[], and testname. However, can't seem to get it to work. Any pointers would be appreciated ?
D.
Post by Pablo » Sun Mar 01, 2020 8:01 am
I'm sorry, currently data of multiple select comboboxes is not supported for MySQL.
This functionality is planned for future release.
