Okay, I'm stumped
Issues related to forms.
iMatt
Okay, I'm stumped
Post by iMatt »
I have been wrestling with creating a form using the Form Wizard to create a form with price options. However, the submit form seems to not be working. What am I doing wrong?
http://www.poetrycards.me.uk/anniversary.php
Re: Okay, I'm stumped
It looks like you have change the 'action' field. Please do not change this.
iMatt
Post by iMatt »
Okay, a test run does get me into PayPal. However, I am presented with a shopping cart for items such as T-Shirts. How do I get rid of these unwanted entries showing in the first place?
You have full control over the properties of the elements. They are standard WWB objects.
iMatt
Post by iMatt »
Okay, I have redone the form. However, it does not seem to be sending info to the URL I need it to.
The names of the form fields do not seem to be correct.
You cannot just use random names. They must be valid PayPal variables:
https://developer.paypal.com/docs/class ... variables/
Is the url in your first post show the redone form?. Asking as when I visit and I view the source I can see that you have removed important code these are "hidden" inputs which look like the following example.
<input type="hidden" name="business" value="paypal@your-web-domain.com">
with this and others missing your form will not work.
I would suggest that you start again as it is the easiest way to get you on track. Note you mentioned T-Shirt you dont have to remove the "hidden" input just rename the field to match your needs ie T-Shirt would become Poetry Cards....
If your still stumped by this let me know and I will try to help.
