Webshop Plus! v.3.2 for WWB8
Navaldesign
Re: Webshop Plus! v.3.2 for WWB8
Post by Navaldesign » Fri Jan 17, 2014 6:25 am
Yes, 3.2 is the latest version.
www.dbtechnosystems.com
adex1
Post by adex1 » Sat Feb 15, 2014 4:45 am
Hi George, I think I read somewhere sometime ago that you charge for options for this extension.
Like what other feature do you charge for?
Thanks in advance.
Buy Automation Shopping Cart for CMS WEBSHOP + 2.2 Using WB10!
- Use secure gateway to buy using PAYPAL website.
Navaldesign
Post by Navaldesign » Sat Feb 15, 2014 11:20 am
For customization of Webshop Plus you can contact me through my site contact form.
bry
Post by bry » Sat Feb 22, 2014 6:43 pm
I just downloaded this and thought I could do a manual install of the extension via WB8. That didn't work.
Specifically, I clicked on Tools/Extension Manager/Manual Install. It looked for a *.wbx file and didn't find one.
What am I missing? Thanks!
Nevermind. I got it done.
thanks
bry
Post by bry » Sat Feb 22, 2014 8:00 pm
I have just put this on a website. Actually, I haven't tested it and I'm only using the following pages: products, cart folder with cart1, customer, checkout, custom_details, thankyou and thankyou1 (why the difference), error and cancel.
I'm not sure how to put a second cart on the same site. Do I need to put each one (with all of the pages mentioned) in individual folders?? I'm not sure how to put the cart folder in a folder. Or maybe I only put the second shopping cart in a separate folder. If so, do I need all of the pages I use in that separate folder - or are some of the pages common to both shopping carts.
Thanks, I hope that is clear!! I really appreciate you giving us a template for this. That made the first one pretty easy (even though I haven't tested it.
Thanks Naval Design. I've got to wait on your answer before I know how to deal with the second cart. Basically, this shopping cart has two different kinds of products.
To answer my own question, I think that I just use (like your sample) two different products pages. Is that right??
thanks
Navaldesign
Post by Navaldesign » Sat Feb 22, 2014 9:14 pm
If you need separate carts, you must install them in separate folders.
Please read the manual, it explains why you have thankyou and thankyou1 (as well as cart and cart1) pages.
bry
Post by bry » Sun Feb 23, 2014 10:19 pm
Thanks NavalDesign. I will be reading that tonight!!
gevers
Post by gevers » Sun Mar 16, 2014 7:49 am
Is it possible to change the language on the order form for print. Do i made the changes in the php code ?
Thanks in advance.
Navaldesign
Post by Navaldesign » Sun Mar 16, 2014 2:57 pm
The backend is only in English as it would require too much effort and code changes to make it multilingual.
If you want to change the labels, you will need to modify the PHP code.
gevers
Post by gevers » Sun Mar 16, 2014 4:58 pm
Ok Thanks.
it is difficult to find the code for the confirmation e-mail to the customer.
Navaldesign
Post by Navaldesign » Sun Mar 16, 2014 6:35 pm
The confirmation mail labels can be set through the Admin area, no need to modify the code.
gevers
Post by gevers » Mon Mar 17, 2014 1:39 pm
Thanks, I need to translate the English terms into Dutch for the mail conformation.
I think thats the php form: dbts_includes/admin_mail_webshop.php.
But i can't find the text
Hello, this email is to confirm that your Order has been received.
Following details have been submitted:
Do i need to edit it els where ?
Navaldesign
Post by Navaldesign » Mon Mar 17, 2014 3:38 pm
You can edit the non-cart labels by double clicking the DBTS Form processor object in the "thankyou" page and editing the Admin mail and Autoresponder mail headers. Please read instructions in the DBTS Form Processor manual.
Also note that to be able to make amendments not only in text but also in font size, color and family, you must have installed the HTML Textbox and HTML Textarea extensions.
gevers
Post by gevers » Mon Mar 17, 2014 10:28 pm
Thank you very much. It worked.
randm
Post by randm » Wed Apr 02, 2014 6:05 pm
Hi Naval
I've been working on a WebShop_Plus_3_2 project for several weeks now, and it was coming along nicely. But since having updated to WB 9.4 yesterday, I am having problems. I thought maybe it was a conflict with one of the extensions I was using, but I tried the entire demo project in a new test site, and it just doesn't publish. The site URL is saying:
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log."
I even started all over again with a new .zip file and re-loaded the demo project, cart folder and Webshop_plus3 folder to my computer. I've tried everything - and this has only been since I upgraded to WB v9.4 yesterday. I had a WebShop project that was working, but after publishing it in WB9.4, it crashed.
I also couldn't find any specific instructions in the PDF concerning where the 10 files included in the webshop_plus3 folder should be uploaded on the server. Should they go inside the "cart" folder, or outside?
Thanks for your great shopping cart - and your help.
