Import products from a CSV file ?
fredphoesh
Post by fredphoesh »
Hello all,
I am selling my CD collection of about 900 disks and do not want to enter each item individually... I know there are w***p***s templates that can import CSV lists of products, but I don't know W***P***s and already own WYSIWYG 14.
Are there any SHOPPING CART addons you know of which can import products from a CSV list? I looked and searched on this site but have not found anything with the terms I searched.
Your help much appreciated.
Thanks,
Mark.
EDITED - it is shopping cart addon I am looking for that can import an item list via csv.
Using 18.0.1
Windows 11 i7, 24gb RAM
Re: Import products from a CSV file ?
fredphoesh
sorry, I should have said, I want a shopping cart addon that can do this. It seems these imply display the spreadsheet data. I'd want it to be a paypal or credit card system that allows me to import a long list of items, only one of each item in stock...
thanks,
Mark.
Using 18.0.1
I'm sorry, there is no standard solution for this. This will require a custom script.
In this case you will need a dedicated/custom script.
fredphoesh
Pablo wrote: Mon Jun 10, 2019 8:33 pm I'm sorry, there is no standard solution for this. This will require a custom script.
Thanks folks. Ok.
I may just try to import a csv to ebay and sell there... Thanks.
Mark.
Using 18.0.1
A quick search of Google using "import csv shopify" minus the quotes may be helpful and you may be able to use the shopify extension.
http://wysiwygwebbuilder.com/shopify.html
