SUGGEST FOR EXTENSION DEVELOPMENT
Re: SUGGEST FOR EXTENSION DEVELOPMENT
WB8
Just sum calendars to check and see if they can be made in to an extension
http://code.google.com/p/planscalendar/ ... stallation
http://joedesigns.com/v22/index.php?pag ... dgets&id=8
http://www.maianevents.com/
===*Item Removed*==
I think this is pretty similar to what Jordan has already created Zinc check this outzinc wrote:It has been a while and I had promised not to post here but after having seen this, I could not resist.
http://janpaepke.github.io/ScrollMagic/
Simply awesome!!!!!! So extension boffins, pretty please![]()
Thanks FX3D, I have removed it, could you do the same. I always fail to check out Jordan's wonderful works!!!!
Sorry Zinc will need a moderator to remove my post as you have replied rendering my post only editable not deletablezinc wrote:Thanks FX3D, I have removed it, could you do the same. I always fail to check out Jordan's wonderful works!!!!
No problems it can stay. As it is not totally like Jordan's anyway. I doubt anyone will make it anyhow.FX3D wrote:Sorry Zinc will need a moderator to remove my post as you have replied rendering my post only editable not deletablezinc wrote:Thanks FX3D, I have removed it, could you do the same. I always fail to check out Jordan's wonderful works!!!!![]()
Just EXCELLENT, i hope someone do it as Extension!!!!!
[b]http://www.ajaxshake.com/plugin/EN/1 ... s.html[/b]
Joe
Joe
This has been done by Patrik. See the extesnion section...
Another request for calendar ext
I found this calendar that does not need a data base http://acalproj.sourceforge.net/features.php
- Patrik iden
stamjoe wrote:Just EXCELLENT, i hope someone do it as Extension!!!!!
Joe
Here you go: viewtopic.php?f=42&t=61608
Thanks PatrikPatrik iden wrote:stamjoe wrote:Just EXCELLENT, i hope someone do it as Extension!!!!!
Joe
i will give it a try!!!!
Joe
- amrajadhyaksha
Any extension for achieving this ?
Copy pasting text from one web site into various Social Media forums is quite common. I am giving here a link where, when you copy and paste a text into another place, it automatically brings with it the URL of the web page too. As an example, I am copy pasting a small portion of the text below:
The Interior Ministry said that at about 8 p.m. Sunday, two minivans entered the town. Militants disembarked and began shooting. Kenya’s National Disaster Operations Center said military surveillance planes were launched shortly afterward.
Read more at http://allenbwest.com/2014/06/im-sick-l ... 4vwSIE5.99
I had copied the text only up to "shortly afterward." The page link with the preceding "Read more at " has appeared by itself.
Any idea on how this happens?
Hello Guys
take a look on this one! http://tholman.com/intense-images/
I think its very usefull!!!!!!
Thanks in advance.
Joe
Thanks in advance.
Joe
