WYSIWYG CMS ( CMS php include ) ***UPDATED 15/10/2009***
Eddy
Post by Eddy » Wed Oct 14, 2009 11:20 pm
I found a security problem for the ajax filemanager, download the cms and read the updated pdf.
Patr100
Post by Patr100 » Fri Oct 16, 2009 1:56 am
I uploaded an inserted an image but when I preview the page I get a blank image holder with the red cross where it should be?
Eddy
Post by Eddy » Fri Oct 16, 2009 6:45 am
If you have used pages in folders ( page not in the same directorie as the cms) than the path to the file is not correct.( php include in the WB page )
Do you have this structure on your server?
Look also to the read and write settings (755) or (777) from your folders.
content
jscripts
uploaded
login.php
webbuilder pages.html
Eddy
Post by Eddy » Fri Oct 16, 2009 6:58 pm
Its not the webbuilder page what you can edit!
This cms works with the same as the News Writer except that the news page is included with php in your WB page.
The "news.html" page is generated and uploaded in the content folder and on that page you write your content.
-If you read "Edit this page!" in the editor than everything is correct.
-Type your text ,insert your images etc and click update.
-Close the editor and renew (F5) your WB page to see the changes.
Patr100
Post by Patr100 » Sun Oct 18, 2009 11:01 pm
Eddy wrote:If you have used pages in folders ( page not in the same directorie as the cms) than the path to the file is not correct.( php include in the WB page )
content
jscripts
uploaded
login.php
Yes I have that structure and read /write permission are corrrect.
Eddy
Post by Eddy » Mon Oct 19, 2009 1:14 am
Is the cms and the pages in the root directorie of your site?,if yes than the only problem I can think of are the file permissions.
Look also to the ajaxfilemanager folder permissions.
Juul
Post by Juul » Mon Oct 19, 2009 6:23 am
Eddy,
Thanks for the tips :wink: , it works!!!!
Juul
Eddy
Post by Eddy » Sat Oct 24, 2009 3:55 pm
In the downloaded zip file is also a folder jscripts ,did you upload that folder to the same directorie as the pages what use the extension.
content
jscripts
uploaded
login.php
Patr100
Post by Patr100 » Sat Oct 24, 2009 4:52 pm
Eddy wrote:Is the cms and the pages in the root directorie of your site?,if yes than the only problem I can think of are the file permissions.
All the permissions fro all the folders are set to 777 or 755.
When I upload an image it is placed in the uploads folder.
But it's stil not showing up on the page.
Eddy
Post by Eddy » Sat Oct 24, 2009 6:29 pm
Are all pages/folders in the root directorie!
1)login and open the news page in the editor
2)upload the image with the ajax file manager.
3)select the image in the filemanager to paste in the news page.(tick the box)
4)close the editor.
5)renew your webbuilder page.
Patr100
Post by Patr100 » Sat Oct 24, 2009 7:06 pm
Eddy wrote:Are all pages/folders in the root directorie!
4)close the editor.
Yes I already siad they are al in the root folder.
I've already done the above.
I am going to empty everything and try again another time.
Eddy
Post by Eddy » Sat Oct 24, 2009 7:40 pm
Sorry,there is not much to configure if all folders and pages are in the same directorie with the right folder permissions than it should work.
Maybe you need to give the ajax file manager folder read and write permissions?
Patr100
Post by Patr100 » Sat Oct 24, 2009 8:27 pm
Eddy wrote:Sorry,there is not much to configure if all folders and pages are in the same directorie with the right folder permissions than it should work.
What specific folder are you referring to?
Eddy
Post by Eddy » Sat Oct 24, 2009 8:34 pm
The folder from the ajax filemanager.
jscripts\tiny_mce\plugins\ajaxfilemanager
Patr100
Post by Patr100 » Sat Oct 24, 2009 8:58 pm
Eddy wrote:The folder from the ajax filemanager.
Just checked it its already 755
