jor_aniMateMASTERPACKv3.0 b5.62___**UPDATE**___b5.63
haakoo
Re: jor_aniMateMASTERPACKv3.0 b5.2 > !UPDATE! > b5.3+tut
Post by haakoo » Sun Dec 21, 2014 9:54 pm
Maar weer even stoeien,Jordan :D
**translate:Having a go at it**
Hans
jordan
Post by jordan » Mon Dec 22, 2014 3:51 pm
haakoo wrote:Maar weer even stoeien,Jordan :D
Hans
hehe haakoo,
happy wrestling - just shout out if you get into a lock hold . :mrgreen: .
digrom
Re: jor_aniMateMASTERPACKv3.0 b5.2 > !UPDATE! > b5.3+tutPara
Post by digrom » Tue Jan 20, 2015 7:41 pm
Hello I have a problem, I use wb9 WB10 and with both the extension does not work even with the templates downloaded from your wesite
jordan
Post by jordan » Wed Jan 21, 2015 12:26 am
hello digrom
what does not work ? - can you open JMPv3.0, is it installed ?
digrom
Post by digrom » Wed Jan 21, 2015 5:40 am
yes, I downloaded the extension and the demo too, but until the demo does not hurt them objects works stopped
sorry my English
jordan
Post by jordan » Wed Jan 21, 2015 1:01 pm
sorry I don't understand you digrom, I need to know - what is not working
please answer this question first - can you open JMPv3.0 inside WB or not ?
digrom
Post by digrom » Thu Jan 22, 2015 12:47 pm
hello really do not know WHAT is happening already downloaded all I will leave here a picture and the demo
image: http://digrom.com.br/test/foto.png
demo: http://digrom.com.br/test/demo.html
if you have some missing please tell me where to download file
jordan
Post by jordan » Thu Jan 22, 2015 2:30 pm
hello digrom,
thank you much for the information
you have set a Target Folder For File Types (js/js) folder in WB, this prevents two JMPv3.0 files from being accessed
remove the Target Folder For File Types (js/js) from WB
digrom
Post by digrom » Fri Jan 23, 2015 4:25 am
thank you solved my problem
jordan
Re: JMPv3.0 - **NEW** - b5.4 - HOLYCOW UPDATE!
Post by jordan » Sat Feb 07, 2015 3:48 pm
jor_aniMateMASTERPACKv3.0 build 5.4 - HOLYCOW UPDATE!
JMPv3.0 build 5.4 is a smaller in numbers but a huge in enhancement - HOLYCOW UPDATE! . :shock: .
JMPv3.0 build 5.4 summary:
- module | onscroll - complete new onscroll mode - 01. ANIMATOR and the NEW 02. ENTER mode
- new easy tools | global disable onscroll option for touch device - (touch/simulate)
- jor_aniMateLIMITER - new option integrated animate.css CSS3 animation library
- jor_aniMateLIMITER - all modules are now disabled by default (see WARNING online manual)
- 2 new online tutorials (draggable handle/basic onscroll enter)
- redesign/cleanup online manual
- other ...
Head over to jorextensions.com and see the new - onscroll online tutorial - download the demo - !HOLYCOW! - you don't want to miss this!
AND OH YEAH - (LAST TIME:) - HOLYCOW - it's - still - FREE!:)
for full update history, demos, tutorials and download see top post
jordan
Post by jordan » Wed Feb 11, 2015 2:14 pm
hello sharpola,
TNX, glad you like it, appreciate the words!
There is already a step by step online tutorial (and demo download) available, see here - JMPv3.0 Online Tutorials
a lot of information can also be found here - JMPv3.0 Online Manual
a click on the link (left-low) in the JMPv3.0 extension will also bring you straight to the JMPv3.0 Online Manual
and after that if your still stuck then just post your question here, just shout out:)
jordan
Re: jor_aniMateMASTERPACKv3.0 - **NEW** - b5.5
Post by jordan » Tue Mar 10, 2015 2:03 am
jor_aniMateMASTERPACKv3.0 build 5.5
JMPv3.0 build 5.5 is a great responsive enhancement update
JMPv3.0 build 5.5 summary:
- responsive enhanced - module | reposition - visibility default state is now false
- responsive enhanced - module | onscroll - visibility default state is now false
- responsive enhanced - module | onscroll - new option - mark default breakpoint
- easy tools | preblock - new option - callback after preblock
- other ...
see also a NEW cool demo with the new responsive enhancements in the jor_INSPIREREYS section on jorextensions.com
sikhoonak2
jor_aniMateMASTERPACKv3.0 b5.5
Post by sikhoonak2 » Sat Apr 11, 2015 2:13 pm
i wanna use 12 object show by this extention but i need to use delay between apear objects
i many search in jor_animatetemplate and cant found any option to set delay in mudole | onscroll
jordan
Re: jor_aniMateMASTERPACKv3.0 b5.5
Post by jordan » Sat Apr 11, 2015 3:13 pm
sikhoonak2 wrote:i wanna use 12 object show by this extention but i need to use delay between apear objects
hi sikhoonak2,
delay is created with the property - enter | offset
it's a position offset in percentage as to when the effect activates in the window viewport
Q:
your other quest/different post - 12 objects, 12 instances ?
A:
if you want to have different effects for each object then yes (simplest) you set up an instance for each object
however, if they all share the same effect then you can use a class instead
add a class to the WB Text Object (=Inside Tag - ie. class='myScrollFX')
then target the class .myScrollFX with the selector property (don't forget the - point in front - it's a class)
hope this helps!
FX3D
Post by FX3D » Sat Apr 11, 2015 3:36 pm
I love your online manual Jordan it is very nice to read and easy to follow, I would love it to have an iframe, layer or pop-up window showcasing the actual section (effect) you are reading about, without having to navigate away from the page.
Maybe just a simple shape or some text so you can visualise the effect you are reading about :P
All in all a great extension with an almost wiki-like information page :mrgreen:
Many Thanks Jordan
