Bottom Slide Out Menu 1.6 (Updated 25/2/2011)
Reptilicious
Re: Bottom Slide Out Menu 1.6 (Updated 25/2/2011)
Post by Reptilicious » Wed Jan 08, 2014 3:54 pm
I didn't know the original builder is not active any more. In other topics about extensions, I also see other builders helping out. Sometimes it's an easy adjustment for another builder to help out. I don't have any knowledge about building extensions, so I also didn't know if my question was something going to be easy to do or not. Since no one replied to my question, I asked again, because I am almost ready to publish my rebuild website and was waiting for an answer.
So thank you for your reply.
Post by BaconFries » Wed Jan 08, 2014 4:38 pm
Yes this is true other builders do help others. But this is not the case here, this requires all the files associated including the original .xwb file which when generated outputs the .wbx (the extension) so that it can be slightly modified to suit you. So without this file then it requires a total rebuild from scratch, and from the screendhot here viewtopic.php?f=42&t=37119 it is more than just a quick fix there is a good few hours to rebuild the extension, then test and then rewrite a new PDF. In saying all this maybe one of the other builders may take it over, but it may take them a couple of days to do so as this is done in there free time. Maybe a offer of a small cash sum for doing this for you may help, but other that it may not get updated soon.
Reptilicious
Post by Reptilicious » Fri Jan 17, 2014 3:46 pm
Thanks for the information, I have found a solution in one of the extensions from Addendum :)
