Web PDF Viewer Extension
Patrik iden
Post by Patrik iden » Wed Aug 12, 2015 9:16 pm
Hello, i just made this Extension - Web PDF Viewer. With this extension you can view PDF files directly in your browser (no need for Adobe Reader).
The Extension short explanation:
I have removed some files from the extension, that made WWB start very slow. There is a download link for these files also. Just unpack the folders in this .rar file and add a File publisher object to your page and put in these folders here, then publish your project.
In the demo page i have a index page that contains the links to the PDF file. I also have an file publisher object at the top left corner where you can add the folders from the extra files .rar file.
The extension it self i have on another page (pdf_test.html).
Demo: http://test3.fcab.se/pdfviewer/test/test_no_files/
Org script: http://www.9lessons.info/2014/06/web-pd ... .html#more
Download (Extension, Extension builder and WWB project files: https://mega.nz/#!4wl3gKRB!wTcj1yBm8UZS ... peYHYy5Nas
Download extra files: https://mega.nz/#!g9kSHKKQ!Z3ZN7BOIwMEt ... PW8yQ4NPnw
Hope you have some use for it :)
gp2727
Re: Web PDF Viewer Extension
Post by gp2727 » Thu Aug 13, 2015 1:47 am
Great Extension, Patrik
Thanks for sharing this extension and source file.
haakoo
Post by haakoo » Thu Aug 13, 2015 9:50 am
If I try to install this extension wb freezes.
If I manually add this extension to my sytem/extension folder wb doesn't open anymore
Seems there's something wrong with the extension
Hans
Patrik iden
Post by Patrik iden » Thu Aug 13, 2015 11:27 am
haakoo wrote:If I try to install this extension wb freezes.
Hans
Strange, it works for me. Are you using the latest version of WWB?
haakoo
Post by haakoo » Thu Aug 13, 2015 11:35 am
Yep latest version,downloaded it again to be sure it is :D
Maybe Pablo can shed a light on this?
Hans
jordan
Post by jordan » Sun Aug 16, 2015 1:54 pm
TNX for your mail Patrik, updated!:)
Patrik iden
Post by Patrik iden » Sun Aug 16, 2015 3:47 pm
jordan wrote:TNX for your mail Patrik, updated!:)
Greate, thank's.
Patrik iden
Post by Patrik iden » Tue Aug 18, 2015 7:20 pm
zinc00 wrote:Thanks Patrik,
Trying it now! :)
BTW Does it work with ver 9
BTW Does it work with ver 9 - I don't know.
Post by BaconFries » Tue Aug 18, 2015 7:49 pm
If the extension was made woth the latest version of the "Extension Builder" then it will only work with the latest version of WYSIWYG wlWeb Builder 10...
Patrik iden
Post by Patrik iden » Wed May 11, 2016 8:12 am
Have you tried publishing my WWB demo, My project may not work as it should. Try this:
1. On the index page, have the PDF images/icons.
2. Make two folders "doc1" and "doc2".
3. Make a page to have the extension on "pdf_test1" and place this page in the folder "doc1", and in the Extension i pick a PDF file.
4. Do the same thing for the second page (note! you should have the file publisher tool with the folders "build" and "images" in it on bouth pages.
5. On the index page click the icons and make links to the bouth pages.
4. Publish all pages and files.
This works for me.
See new demo page: http://test3.fcab.se/pdfviewer/test/
MUDJ
Post by MUDJ » Wed Apr 19, 2017 5:56 pm
Hi Patrik! Sorry for misunderstanding!
I've the last version of wwb, the 12.0.2.
I've test to open preview of your project with this extension but have same problem to visualize correctly such as my site and i not understand if it's normal offline or not.
If is possible, i need help from You to insert the extension on my company site step by step.
I've 3 catalogs pdf. One of it is of 70 mb.
First... not consider the index page. i not start to 0. I explain in a few words..
Into index page, i've intro full responsive, with a click redirect to home.
Into menu i've "catalogs" that if clicked, have a bookmark that redirect to login and then login redirect to catalogs page.
In catalogs page have 3 brands.
If click on one brand, i've setting a bookmark in a same page that i want that select the start catalog space to visualize pdf.
If i put the extension on layout grid (full width) and select pdf, in preview change total background in a gray colour and is not correct for the site. My background is black.
Now.. first.. is possible to open in a same page the pdf into a extension? Or i'm obliget to create new page and, from catalogs page, link the extension in other page?
Eventually is possible insert a inline frame and visualize in a precise space for catalog the page with pdf is responsive mode?
Now i hope you understand my position with my site and hope you help me.
