Use it if you want
RiaanN
Use it if you want
Post by RiaanN » Tue Jun 05, 2018 4:51 pm
3D Slider with HTML, no Jquery used.
Edit the file and insert your own 9 images. Image size of 300 x 180 works well
***link removed***
Regards
Riaan
Re: Use it if you want
Post by BaconFries » Tue Jun 05, 2018 5:02 pm
Please read the following before posting
*** MUST READ *** Please read this before posting extensions things information you need to give in post a link to original site, credits to original author etc or I will remove..
Then why is there reference in the Page HTML source if it doesn't use jQuery.
Post by BaconFries » Tue Jun 05, 2018 6:10 pm
@RiaanN I have removed the link for the following
No reference to the original author of the code script used!
On downloading myself there is reference to jQuery which you
say it doesn't!
The files downloaded show in the jQuery that the code was made by another member 'spoon' to which he was warned about modifying code not his own.
Looks like you may have just copied his 'spoon' extension as passed as your own.
Feel free to contact Pablo if you wish on this as I will write to him also.
Reference to member 'spoon'
https://www.wysiwygwebbuilder.com/forum ... 42&t=80508
Users browsing this forum: No registered users and 8 guests
