Adding custom fields to Admin object
TIP:
alex4orly
Post by alex4orly » Sun Apr 30, 2017 8:00 am
I want to add a new field - A combo box with a few options
I tried using the : Collection->Option with the following code, this doesn't work...
<select>
<option value="volvo">Volvo</option>
<option value="saab">Saab</option>
<option value="opel">Opel</option>
<option value="audi">Audi</option>
</select>
Re: Adding custom fields to Admin object
Post by Pablo » Sun Apr 30, 2017 9:15 am
What exactly does not work?
What are your exact settings?
What is the result?
alex4orly
Post by alex4orly » Sun Apr 30, 2017 9:31 pm
Please have a look at : http://www.nmaa-rc.org.au/admin3.php
It comes up as an empty frame, I tried changing the code to the following
<select name="extra3" size="1" id="Combobox1">
</select>
Post by Pablo » Mon May 01, 2017 6:39 am
Do you mean that the entire page does not work only because you have added this code?
In that case there must be an error in the PHP code somewhere.
I think it is helpful is you enabled PHP error reporting on the server so you can see where it stops working.
alex4orly
Post by alex4orly » Mon May 01, 2017 8:23 am
There is a problem on that website, I am waiting for the host platform to get back to me.
In the meantime, I repeated my setup here : http://www.beleuramyhome.org.au/page4.php
I added one extra item into the collection with the following code:
<select name="cars">
<option value="fiat">Fiat</option>
</select>
When I run this page I get an error which I don't understand
Hope you can help me
Post by Pablo » Mon May 01, 2017 11:15 am
I'm sorry I cannot find the specified page.
What do I need to do to see the the problem?
alex4orly
Post by alex4orly » Mon May 01, 2017 11:42 am
Please go to : http://www.beleuramyhome.org.au/
Then type at the continuation : page4.php
And you will get it
alex4orly
Post by alex4orly » Mon May 01, 2017 11:47 am
The error is :
Parse error: syntax error, unexpected T_STRING in /home/bebe2839/public_html/loginadmin.php on line 497
In the script on that line there is :
case "<select name="cars">":
$selected[0] = "selected";
break;
case " <option value="volvo">Volvo</option>":
$selected[1] = "selected";
break;
case " <option value="saab">Saab</option>":
$selected[2] = "selected";
break;
case " <option value="fiat">Fiat</option>":
$selected[3] = "selected";
break;
case " <option value="audi">Audi</option>":
$selected[4] = "selected";
break;
case "</select>":
$selected[5] = "selected";
break;
case "":
$selected[6] = "selected";
break;
Post by Pablo » Mon May 01, 2017 11:52 am
The code is invalid. This is not valid PHP code. Was this code generated by Web Builder?
If yes, then please share your project so I can see your settings.
Post by Pablo » Mon May 01, 2017 3:04 pm
Thanks for sending the project. Options should be added like this:
Volvo
Saab
Fiat
Audi
not with HTML code.
alex4orly
Post by alex4orly » Mon May 01, 2017 8:33 pm
Thanks, that works just fine
I wonder, how does WWB know I want a combobox....
Cheers
Post by Pablo » Mon May 01, 2017 8:36 pm
Because if you select 'options' this will automatically create a combobox.
From the help:
New fields can be of type' text', 'option' or 'checkbox'. A text field adds a standard editbox ,while the option fields adds a combobox to give the user multiple choices.
