New password for phpMyadmin (ovh)
TIP:
Re: New password for phpMyadmin (ovh)
Post by Pablo » Wed Sep 20, 2017 7:23 am
Du you think a must reinstall WWB ?
No.
You will need to find out which database functionality you have used.
Note that I cannot see what you have done based on the HTML only.
I need to see your project file or the PHP code.
jolijojo
Post by jolijojo » Wed Sep 20, 2017 7:30 am
I have send the file, but why i have not extension about admin, login... in my toolbox ?
Post by Pablo » Wed Sep 20, 2017 7:55 am
There is no mySQL functionality in the project you have sent me.
I think it's best if you contact your webhost for assistance. This is not related to WWB.
jolijojo
Post by jolijojo » Wed Sep 20, 2017 8:07 am
And my webhost say:
Merci pour votre retour Jean-Pierre,
Pour des raisons de sécurité et de confidentialité, nous n'avons pas accès à
votre espace ftp, de ce fait, il n'est pas possible de nous intervenir pour
vérifier les paramètres et les scripts de votre site.
Le fichier de configuration doit être reconnu de la part du développeur du
site.
De ce fait, je suis au regret de vous informer que ces vérifications sont hors
de notre périmètre en tant que support, je vous invite à contacter votre
web-master ou bien l'un de nos partenaires via ce lien:
I do not understand why avironmer.fr have a problem and avironmer.fr/ligue/index.php not problem ?
Post by Pablo » Wed Sep 20, 2017 8:59 am
There is no MySQL code in the project you have sent me.
So either you have sent me the wrong project or the problem is on the server.
Only your host can help you with this. Their server is generating this error!
jolijojo
Post by jolijojo » Wed Sep 20, 2017 10:16 am
i have recall to my webhost, for him no problem.
If a send you my FTP codes, can you verify please.
Post by BaconFries » Wed Sep 20, 2017 11:38 am
@jolijojo the following message is from your host/server. It indicates that access is denied this usually can mean that the username is wrong or the password. You yourself have said you changed this in the first post. To fix you need to contact your host/server provider to fix.
MySQL connection error: .Access denied for user 'avironmeyh013'@'10.0.27.47' (using password: YES)
You also say on a later post that you are not used any form tools in WWB such as login object so if you haven't then there will be no database, no PHP to cause errors.
I think you are having login issues to your hosting account why? because you have said admitted you have changed the password if you have then this has nothing to do with WWB but with your host and only and only they can fix.
jolijojo
Post by jolijojo » Wed Sep 20, 2017 11:48 am
j'ai très bien compris, chacun me dit que c'est l'autre.
Seul le site principal ne fonctionne pas, le site "ligue" et le "forum" fonctionnent très bien sans avoir changé quelque chose.
La personne du serveur a tenté de retrouvé dans quel fichier se trouve le password.
I understood very well, everyone tells me it's the other.
Only the main site does not work, the site "ligue" and the "forum" work very well without having changed something.
The server person tried to find the file in which password is located.
Post by BaconFries » Wed Sep 20, 2017 12:09 pm
phpMyadmin is server related and has nothing to do with WWB, so if you have changed the password to it that is were the issue lies. You or should contact your host/server and ask them to resolve or even reset this for you, if the cannot then maybe reading the following will help. Please note that this is unrelated to WWB but with what or may have done by changing the password.
From a Google search using the following parameters
password for phpMyadmin (ovh) gave me this
http://help.ovh.co.uk/ModifyPhpMyAdmin
Post by Pablo » Wed Sep 20, 2017 2:00 pm
What is the PHP code of the page that does not work?
jolijojo
Post by jolijojo » Wed Sep 20, 2017 3:50 pm
"Cette après-midi je devais faire une démo avec mon site, le client veut maintenant que je le site avec wordpress.
J'ai changé de password parce-que je l'avais oublié.
En lançant le site la réponse est :"
This afternoon I had to make a demo with my site, now the client want his site with wordpress
I changed my password because I had forgotten it.
When launching the site the answer is:
I will try to change again the password
Post by Pablo » Wed Sep 20, 2017 4:01 pm
I do not think this problem has anything to do with WWB.
Maybe you have overwritten the WWB website with Wordpress?
