I'm using the login tools demo and it fails to send a email notification when a new user signs up and I get the following php error when I try to reset the password using the password recovery tools.
Any help would be appreciated
[14-Mar-2018 18:21:01 UTC] PHP Notice: Undefined variable: newpassword in /home/lightnin/public_html/englishtaekwondo.co.uk/logindemo/forgot_password.php on line 36
Login Tools PHP Error $newpassword
TIP:
TIP:
Re: Login Tools PHP Error $newpassword
This usually means that the PHP warning level on the server is set high, so it checks all variables.
You can either turn off error reporting on the server or add this code at the start of the page:
<?php
$newpassword = '';
Hi
Thanks for the response, did you mean the start of each php page ?
Thanks for your help
BR
Chris
BR
Chris
I meant the start of the page with the 'password recovery' object.
