Login tools in two languages
TIP:
Aris
Post by Aris » Thu Apr 26, 2018 7:35 pm
Hi.
I would wish your advise in the following problem:
My site is addressed to visitors who speak Greek and English language.
How may I manipulate the labels of Login tools (login, sign up, forgot password etc)?
1. May I have two pages (in Greek and in English) for every login tool?
2. Or there is some other solution?
Thank you.
Re: Login tools in two languages
Post by Pablo » Thu Apr 26, 2018 7:54 pm
Yes, that is possible.
Any other solution would require programming.
Aris
Post by Aris » Fri Apr 27, 2018 3:57 am
I think it has to do with PHP.
Can you suggest to me a programmer or some software in order to help me?
Thank you.
Post by Pablo » Fri Apr 27, 2018 6:16 am
I'm sorry, I do not know any software that can do this automatically.
But maybe you can use google translate on your website?
Aris
Post by Aris » Tue May 01, 2018 4:57 pm
Thank you, Pablo.
Probably, my question seems stupid: "Google translate" changes and the labels of login tools?
Aris
Post by Aris » Tue May 01, 2018 4:59 pm
Sorry, I mean: "Google translate" changes and the language of the labels in login tools?
Post by Pablo » Tue May 01, 2018 5:14 pm
I do not know if that will work, but you can try.
Aris
Post by Aris » Tue May 01, 2018 5:32 pm
Thank you, Pablo.
I will try.
