"Not active" in Login Admin file allowing access
TIP:
trenoweth
Re: "Not active" in Login Admin file allowing access
Post by trenoweth » Tue Jun 05, 2018 7:31 am
So if I rearrange it so that the active field is number five, that should resolve things?
I do still have active as 5, though starting with 0 that probably means it is really 6
This is my amended coding:
$values = explode('|', trim($line));
$values[0] = $_POST['login'];
if (!empty($_POST['password']))
$values[1] = md5($_POST['password']);
$values[2] = $_POST['email'];
$values[3] = $_POST['firstname'];
$values[4] = $_POST['surname'];
$values[5] = $_POST['active'];
With corresponding amendment elsewhere.
Would simply moving the active field work so that, for example, I have (1) User name,(2) First name, (3) Surname, (4) Email, (5) Active with the hidden password field for the sixth one?
You have asked which version I have, but where is that shown? As I have said I downloaded it on 4th June, but these files were already in existence then. When I look at the About tab it just has Version 14 (May 7 2018), as here.
Anyway, these files were produced in an earlier version.
Post by Pablo » Tue Jun 05, 2018 7:36 am
Correct
All standard fields need to be in their original position, extra fields should be added at the end of the line.
This is not the most recent version. Please install the latest update.
https://www.wysiwygwebbuilder.com/forum ... um.php?f=1
trenoweth
Post by trenoweth » Tue Jun 05, 2018 7:39 am
Well, it is what I downloaded this very week!
trenoweth
Post by trenoweth » Tue Jun 05, 2018 7:43 am
Is this 14.0.4 an update or a new paid-for program? It's only just over two months since I last paid you for an upgrade!
Post by Pablo » Tue Jun 05, 2018 8:57 am
If you have a license for version 14.x then all updates for this version are free.
trenoweth
Post by trenoweth » Tue Jun 05, 2018 9:14 am
I have, thank goodness!
trenoweth
Edit problem in Login Admin file
Post by trenoweth » Wed Jun 06, 2018 2:10 am
Now I have another problem! Using v14.0.4 and writing completely new files without any additional field added the program works alright as far as signing-up and using the admin page are concerned, also the active/not active function. But when I click on edit I can see that a new sign-up is denoted as an Administrator. Changing that to 'Member' or 'Guest' and saving doesn't, in fact, have any effect as when checking the edit box again it is still showing 'Administrator'.
Post by Pablo » Wed Jun 06, 2018 6:01 am
User roles and avatars in WWB14 only work with MySQL database. This functionality was not designed to be used with flat database.
trenoweth
Post by trenoweth » Wed Jun 06, 2018 6:08 am
Ah, right, well ... I don't really require the roles so that's not a problem for me. Thanks.
Better have a look at MySQL when I have a moment though.
