Edit Profile Error
TIP:
Markoc
Re: Edit Profile Error
Post by Markoc » Fri Jun 15, 2018 6:55 pm
I'm trying something new to maybe isolate the problem.
I see that you have a new update that shows the avatar when converted to html. Thanks for doing that.
I noticed though that the button to browse for a new avatar only shows up as a small box and it's not clickable. Could you have a look at that?
I've added a screen shot of what I see. The one on the right is the convert to form.
Thanks again!
Post by Pablo » Fri Jun 15, 2018 8:09 pm
It looks like the style sheet is missing.
Did you publish all files?
Markoc
Post by Markoc » Sat Jun 16, 2018 12:03 am
I did publish the page. Doesn't it upload the style sheet with It?
Post by Pablo » Sat Jun 16, 2018 6:41 am
Yes, if you publish all files.
Something is wrong with the styles. So, either the style sheet is missing or there is a naming conflict.
