Issue with "Between <style>tag" in EB 5.3.1
presto
Post by presto » Fri Feb 12, 2016 10:48 am
Code inserted in the tab "Between <style>tag" of EB 5.3.1 is not included in the generated HTML code.
Re: Issue with "Between <style>tag" in EB 5.3.1
Post by Pablo » Fri Feb 12, 2016 11:08 am
It seems to work correct.
presto
Post by presto » Fri Feb 12, 2016 12:22 pm
It works for me when extension has been build and site is published from WWB11, but not in preview of EB 5.3.1.
Post by Pablo » Fri Feb 12, 2016 12:23 pm
Correct. This functionality has not been implemented in Extension Builder.
presto
Post by presto » Fri Feb 12, 2016 12:28 pm
Pablo wrote:Correct. This functionality has not been implemented in Extension Builder.
I see. Thank you for the clarification.
