WWB11 keep display "extension" as Extension name when i install custom extension made in extension builder
xavier@cribelier.fr
Post by xavier@cribelier.fr » Thu Mar 16, 2017 5:00 pm
Hello,
WWB11.6.4 keeps display "Extension" as Extension name when i install custom extension made in extension builder.
And the Extension is not available i have a rectangle with "MyExtension.uwbx" instead...
Please can you help?
Best regards
Xavier
Re: WWB11 keep display "extension" as Extension name when i install custom extension made in extension builder
Post by Pablo » Thu Mar 16, 2017 6:29 pm
Did you close the software when you updated the extension?
xavier@cribelier.fr
Post by xavier@cribelier.fr » Fri Mar 17, 2017 6:57 am
Hello
Yes i closed it and reopen and reclosed and reopen...
Post by Pablo » Fri Mar 17, 2017 7:18 am
Maybe the file is read-only?
I do not think this has anything to do with WWB itself because there are hundreds of extensions that do work properly.
xavier@cribelier.fr
Post by xavier@cribelier.fr » Fri Mar 17, 2017 9:35 am
No the file is not read-only
I can't find the way to avoid the pb
Post by Pablo » Fri Mar 17, 2017 10:00 am
Do you have the same problem with all other extensions or only with your own extension?
xavier@cribelier.fr
Post by xavier@cribelier.fr » Fri Mar 17, 2017 3:52 pm
only with my own extensions, it does the same things with all my extensions
Post by Pablo » Fri Mar 17, 2017 4:24 pm
Then maybe you are changing the wrong value in the extension builder?
