Extension ID field
GrahamW
Extension ID field
Post by GrahamW » Sat Feb 10, 2018 7:29 am
can you add a field into an extension that will automatically place its name in the ID field when it is placed on the page instead of it saying extension 1 or extension 2 etc.
If so how do you do it.
Graham
Re: Extension ID field
Post by Pablo » Sat Feb 10, 2018 8:24 am
No, there is no option for that.
But course you can implement you own 'ID' property and ignore the one that WWB generates.
GrahamW
Post by GrahamW » Sat Feb 10, 2018 8:33 am
thanks Pablo thats what I have been doing with it
