CMS SHOP + 2.2 RELASED!!!
Please post commercial templates here.
adex1
Re: CMS SHOP + 2.2 RELASED!!!
Post by adex1 » Sat May 24, 2014 9:35 pm
mindentezzel wrote:I hope I post this message in the right place.
My query: is there an e-book (software, picture etc) shop in this version? I seek a normal e-book store solution, where after paying the costumer can download the book or picture or software. Would you please give me a feed back about it? There are two big questions, how many times can the costumer download the book, and how can you give back the money if he/she got the book.
Thanks, T.
Yeah it has everything you want.
Have a look at this:
URL removed
and backend
http://www.cmsplus.bbbweb.be/get_start.php#categorys
Buy Automation Shopping Cart for CMS WEBSHOP + 2.2 Using WB10!
- Use secure gateway to buy using PAYPAL website.
kuasarx
Post by kuasarx » Mon May 26, 2014 8:26 am
basstuuk wrote:Hallo,
Heb een email aan k gestuurd maar krijg geen antwoord.
Heb de webshop gekocht maar geen serienummer toegestuurd gekregen.
Misschien dat het zo lukt om antwoord te krijgen.
Met vriendelijke groet Bas :(
Ik heb de serienummer opnieuw gestuurd.
vergeet niet jij moet het gebruiken in combinatie met uw e-mail in de installatie process.
indien jij meer vragen heft, dan kunt jij contact met mij opnemen via info@bbbweb.be
Web Design , CMS Systems & e-commerce for WYSIWYG 9
adex1
Post by adex1 » Mon Jun 02, 2014 5:39 pm
Phuzznutz wrote:How much does this cost in US Dollars?
Start cost from 35euros. Check below link
http://www.cmsplus.bbbweb.be/view.php?p ... andard-ade
Post by BaconFries » Mon Jun 02, 2014 5:50 pm
@adex1 if you are pointing to your site to sell this then I will remove it again as it is not polite to advertise what you are selling in the original members thread. It is not polite to do this and unfair on the orininal seller of the template.
adex1
Post by adex1 » Tue Jun 10, 2014 7:31 am
BaconFries wrote:@adex1 if you are pointing to your site to sell this then I will remove it again as it is not polite to advertise what you are selling in the original members thread. It is not polite to do this and unfair on the orininal seller of the template.
@BF: I am not selling anything on my website. I was pointing to the website I built with the extension.
Is that the reason inject the website and always after my posts for deleting?
kuasarx
Post by kuasarx » Sun Dec 14, 2014 10:23 pm
bryaninuk2 wrote:Hi there, just bought the product and I am not happy with the template, is it possible to embed the products form onto my existing website? I would then be able to use the backend, which looks very good, with my website. What code would I need to copy over to my existing site?
When I bought it I did not realise it was so dependant upon the template.
Thanks Bryan
Hi bryaninuk2.
Yes in fact the shop is template dependant, it carries the 35% of the work.
The best option is that you change the template for suit your needs.
Contact me at info@bbbweb.be and I will help you foward.
thanks.
mayur007
Post by mayur007 » Sun Apr 19, 2015 8:30 pm
hi i m trying to login in the admin panel
but says
THE COMBINATION OF USERNAME AND PASSWORD IS NOT RECOGNIZED.
PLEASE TRY AGAIN.
adex1
Post by adex1 » Sun Apr 19, 2015 9:15 pm
mayur007 wrote:hi i m trying to login in the admin panel
but says
PLEASE TRY AGAIN.
Hi, at the moment you can not login. Sorry for any inconvenience this might have cause you for not having access to the backend.
mayur007
Post by mayur007 » Mon Apr 20, 2015 10:43 am
ok do let me know although i can wait till Wednesday at max
cdasupport
Post by cdasupport » Sun Jan 17, 2016 1:56 am
How is it that the test viewing login & password for front end & back end do not work ?
me.prosenjeet
Post by me.prosenjeet » Sun Jan 17, 2016 6:51 am
Re: cdasupport
Last post by kuasarx was on December 14th 2014. We are not really sure if he is still active on the forum or if he still supports the extension, Also, if the extension works on the latest WB 10X moving to WB11 soon
www.Lucknowwebs.com
cadtec
Post by cadtec » Tue Mar 01, 2016 3:10 pm
Interessting Product!!!
Does it work with WWB 11?
Best regards,
André
Sharid
Post by Sharid » Sat Mar 26, 2016 7:04 pm
Hi
RE:http://www.cmsplus.bbbweb.be/listing.php
I'm interested in this product and just need an update on who actually owns this. The site has broken links and has not been updated for about a year now, so don’t even know if the product is still available, or updated.
I have emailed the site direct a couple of times a few months back but got no reply.
I have a few questions for anyone to answer.
1. Has anyone bought this in the last few weeks/months?
2. Will this work on WB version 11 or is this just for WB10?
3. Has anyone had any contact with the owner of this product in the last few weeks and months?
Having read some of the posts. Below and it’s a bit confusing and who owns this
me.prosenjeet replyed to cdasupport on Sun Jan 17, 2016 7:51 am
Re: cdasupport
Is the owner of this product kuasarx ?
or
Is adex1 the owner as he replied on April 20, 2015 11.43am
adex1 is still active on the forum? and has a link to the site as part of his signature, or is he only bringing thr product to our attention?
There has not been an update to cadtec post on tue March 01. I'm not sure what to think, Please help as -
I'm also interested in this product but don't know who to contact. I don't want to risk buying if it is not compatable with V11 and no further updates as I wanted the webshop + Lifetime update version. :oops:
Sharid
Post by Sharid » Sat Mar 26, 2016 7:08 pm
I've just realised that this is a post for cms Shop 2.2. and adex1 signature is for cms webshop 2.2 are these different or the same products? sorry as i might have them mixed up. please advise
me.prosenjeet
Post by me.prosenjeet » Sat Mar 26, 2016 7:14 pm
Looking at the status I get a feel that the product may or may not work with wb10/11. There has been no updates from the author so my suggestion is - dont risk it
Look for other such extension and you will find some shopping cart - free and pro paid ones too.
Best pf luck
www.Lucknowwebs.com
