Need template
Please post commercial templates here.
Mikeone
Need template
Post by Mikeone » Thu Jul 14, 2016 11:18 am
Hi Guys,
I want to made a backoffice admin website, but i dont have so much time and need someone who can offer me its services, i am looking for a Left panel, with top bar and footer bar responsive like this or similar: https://colorlib.com/polygon/gentelella/index.html
Must be made with wysiwygwebbuilder which will allow me to add menu items and made my own changes.
I only need those 3 items fully responsive. It must be easy to modify. Please pm me with a reasonable offer.
Thanks in advance
Mike
me.prosenjeet
Re: Need template
Post by me.prosenjeet » Thu Jul 14, 2016 2:20 pm
Here there are some templates with live demo. See if you find any useful:
http://lucknowwebs.com/downloads/templa ... -templates
www.Lucknowwebs.com
pajadt
Re: Need template
Post by pajadt » Thu Jul 14, 2016 4:38 pm
Hi Mike,
Your example is create with bootstrap, as i see you try to implement PHP or any server side language and make it Admin Panel like you have for Prestashop or wordpress
Create same with WWB is not posible / because we dont have vertical menu like that, WWB CMS is not responsive etc / way how can create this what u want is coding html and css, but in that way u must know coding if you want something to change.
Other way is to we create with bootstrap, and sell to you. or u can buy template dashborad from web wich sell template like this.
After that u must to implement PHP that is a long project depending on what feature you need and how you needs, we can do also
Anyway i need more info about this project or contact to me
maxime
Re: Need template
Post by maxime » Thu Jul 14, 2016 8:52 pm
i think you are wrong there is menu who can act like the one he is showing.
pajadt
Re: Need template
Post by pajadt » Fri Jul 15, 2016 12:38 am
Maxime, I talk about vertical menu to be same . Menu like this at example not have WWB this menu used jquery script and not have WWB as i know. Maybe have but i not see.
Mikeone
Re: Need template
Post by Mikeone » Fri Jul 15, 2016 9:27 am
Thanks guys
I have my admin website done in php, actually using responsive Menu. But i like that design using bootstrap. A Top bar with user details menu and a left menu which slides when you move mouse over, thats what i am looking for.Maybe is possible to do with layers but as i said i have no time now for that.
My skype: miflop
Regards
Miguel
