Password Protect Project File?
bmnb
Post by bmnb » Thu Jul 27, 2017 6:15 pm
Hi Pablo, how are you?
Is there any way to password protect project files?
Thanks indeed and have a Blessed Day...
Re: Password Protect Project File?
Post by Pablo » Thu Jul 27, 2017 6:21 pm
(PHP) password protection only works on HTML pages, because you cannot add PHP code to other files.
To protect files you will need to configure a password protected folder on the server.
Post by [RZ] » Thu Jul 27, 2017 6:35 pm
@admin
if i'm not wrong, i guess the op asks for a way to encrypt the wb project file and enter a password to open it, like in pdf viewers
Post by Pablo » Thu Jul 27, 2017 8:21 pm
I'm sorry I did not get that form the question :oops:
No, that is not possible.
Biju
Post by Biju » Fri Jul 28, 2017 8:36 am
After publishing just zip your project folder with password :D
or use any file encryption tool..
~ Remain Curious
and Keep Learning ~
_________________
www.philip.epizy.com
