The carousel and the fixed mesh
spoon
Post by spoon » Thu Oct 26, 2017 9:39 am
This question has a fixed mesh cap underneath the carousel settings full width and floating when viewing the carousel comes under the net.
If the carousel set to full width, it seems like everything is OK, carousel Prilepy to the cap but then the text in the grid which is under the carousel sticks to the cap.
Re: The carousel and the fixed mesh
Post by Pablo » Thu Oct 26, 2017 9:45 am
I'm sorry but is it not clear what you are trying to do.
What is the URL of the page?
What are your settings?
or where can I download your project file?
spoon
Post by spoon » Thu Oct 26, 2017 9:48 am
Post by Pablo » Thu Oct 26, 2017 10:01 am
The Carousel is behind the layout grid because you have set it to 'fixed'. Fixed objects are not floating so they do not affect the position of other objects. This is normal HTML behavior.
If you wish to have an offset then you can add a margin to the top of the Carousel.
spoon
Post by spoon » Thu Oct 26, 2017 10:05 am
margin-top?
This is the only option?
Post by Pablo » Thu Oct 26, 2017 11:10 am
Yes, that is the best option.
