Responsive menu icons/text padding or spacing
SlyJacob
Post by SlyJacob » Tue Jan 23, 2018 11:00 pm
Is there any way to add spacing / padding between the text and icons in responsive menu? They are too tight at the moment.
I couldn't find it anywhere in WB, only idea I had was to edit it in the final css, but the problem is that it gets overwritten everytime I publish new version of the site, so that's quite meaningless.
Re: Responsive menu icons/text padding or spacing
Post by Pablo » Wed Jan 24, 2018 7:04 am
There is currently no standard option for this.
You can post suggestions in the 'Suggestions' section of this forum.
SlyJacob
Post by SlyJacob » Wed Jan 24, 2018 8:48 am
I'm sorry there is currently no standard option for this.
Would you have any recommendations for now? How to do it other way? I am building the page to be as responsive as possible, using layout grids, so throwing an image (icon) above text doesn't seem like the best option in my opinion.
Post by Pablo » Wed Jan 24, 2018 9:18 am
I'm sorry there is no option to add spacing between the text.
But if you place the icon at the left or right then you can use a space to add some extra spacing.
SlyJacob
Post by SlyJacob » Thu Jan 25, 2018 7:57 am
Thanks Pablo, loving your product, saves me alot of time!
SlyJacob
Post by SlyJacob » Sat Jan 27, 2018 7:47 pm
I got back to the menu, but I found no way of putting the icons to the left of the text. I am using the Responsive menu from toolbox.
Post by Pablo » Sat Jan 27, 2018 9:50 pm
You are right, the responsive menu currently does not have this option.
I was confused with the Boot Strap Menu.
http://wysiwygwebbuilder.com/bootstrapn ... onbar.html
