CMS template
RiaanN
CMS template
Post by RiaanN » Fri Feb 02, 2018 2:01 pm
Good Day
I am playing around with the CMS template that came with the web builder software. I just want to find out if that is the only version available because I cannot connect to the admin because the current version that I have does not provide for connection options to the data base, and I know on my side it must be MySQLi
Regards
RiaanN
Re: CMS template
Post by Pablo » Fri Feb 02, 2018 2:20 pm
If you select 'PHP5' in the page properties then MySQLi will be used for all generated PHP code.
gwathne
Re: CMS template
Post by gwathne » Sat Feb 17, 2018 9:22 pm
Hi. There's only two templates with my installation og wwb12. I want to use CMS but can't figure out what to download?
There's a lot of templates to download but i can't see any way to search among them...
What template to download?
Re: CMS template
Post by Pablo » Sat Feb 17, 2018 9:27 pm
The CMS template is included in the setup.
If it's not in the list then you may have changed the template folder in the configuration.
http://wysiwygwebbuilder.com/using_templates.html
gwathne
Re: CMS template
Post by gwathne » Sat Feb 17, 2018 9:45 pm
But the folder C:\Users\gwath\Documents\WYSIWYG Web Builder\system\templates
containes 5 templates. 3 old ones from previous versions and two .wtp templates , Blue Greyscale and Buissnis Company template.
But in't there any place i can download it, or maybe mail it to me?
Re: CMS template
Post by BaconFries » Sat Feb 17, 2018 9:55 pm
Seethe following:
Blocks, Extensions and Tempates are no longer in the list!
And the link at above.
Re: CMS template
Post by Pablo » Sat Feb 17, 2018 10:02 pm
You cannot download the templates separately, they are included in the setup.
The setup installs 16 templates.
gwathne
Re: CMS template
Post by gwathne » Sun Feb 18, 2018 8:02 am
Now i have tried to reinstall the program i downloaded but the list of templates does not change?
I can only see two templates in the list.
Do you know a name and place i can buy and download a working template? Not too expensive?
Re: CMS template
Post by Pablo » Sun Feb 18, 2018 8:15 am
You do not need to download or buy the templates, they are included in the setup!
Did you read this?
http://www.wysiwygwebbuilder.com/forum/ ... 10&t=76719
gwathne
Re: CMS template
Post by gwathne » Sun Feb 18, 2018 8:25 am
Yes and those folders are there, but as i said they containes 3 old templates from oldwysiwyg and they dont shoe up in the list. Then there is the two templates that showes up in the list, but they don't contain cms.
isn't it possible to just copy the template and copy it in to the template folder?
Re: CMS template
Post by Pablo » Sun Feb 18, 2018 8:38 am
I think you are looking in the wrong folder. Or the folder is read-only, so no new files can be saved in there.
What happens when you remove or rename the entire folder before you run the setup?
gwathne
Re: CMS template
Post by gwathne » Sun Feb 18, 2018 12:20 pm
Now i have made a backup, uninstalled wysiwyg, and deleted the system folder in wysiwyg's folder.
Then i reinstalled wysiwyg and the first start made it create the system folders again.
Only difference is that now i don't have any templates at all...
I can click on the link to visit your homepage to download templates, but witch template is it that has a complete cms setup?
Re: CMS template
Post by BaconFries » Sun Feb 18, 2018 12:27 pm
None! the CMS is part of the 16 templates that come preinstalled when you first install the software, this has been previously mentioned that it isnt in any other. When you reinstalled did you close and restart the software? this is a requirement if not please do so and see if that helps, have you checked the permissions of the folders? are the read only? if so they need to be writable so the contents can be written to them. Have you tried to run and install as a Admin? I would try this along with permissions and let us know.
Re: CMS template
Post by Pablo » Sun Feb 18, 2018 12:35 pm
Did you get any errors during the setup?
Did you download the setup from the official website?
http://wysiwygwebbuilder.com/download.html
Did you run the setup with admin permissions?
gwathne
Re: CMS template
Post by gwathne » Sun Feb 18, 2018 2:16 pm
I am logged in as an ordinary user on my computer. When installing i have to give admin permision to make changes to the computer. If i logg in as admin and install then the wysiwyg folders will end up in the admins document folder?
Or does it work; installing as admin and each user that starts wysiwyg will get their own system folder from wysiwyg?
I can uninstall and try that way?
