Blank leading space before text in each paragraph
TAK
Post by TAK » Fri Feb 23, 2018 11:01 pm
Using 12.4.0. There is a blank character space before the first text character on the first line of the first paragraph of a text box. I don't see a property to fix to stop this behavior. It appears in Chrome, Firefox browsers.
Please see the following link and associated pages for example:
http://www.estoreliefusa.org/home_eng.html
Re: Blank leading space before text in each paragraph
Post by Pablo » Sat Feb 24, 2018 7:51 am
The space is caused by the padding you have added to the style: Text_11_Arial_1_2. It is set to 4 pixels.
Note that if you use a style on text then it will be applied to the characters, not to the container of the text.
If you want to add padding the text's container then you can do this in the properties of the text object.
