Scroll Transitions is not working on property: color.
spoon
Post by spoon » Tue Mar 06, 2018 1:52 pm
Hello, there was a problem in css animation doing color replacement title when scrolling, but the color does not change because there is a priority color by item ID. What to do, could you tell me?
link
Re: Scroll Transitions is not working on property: color.
Post by Pablo » Tue Mar 06, 2018 2:09 pm
The animation will be applied to the object's container, but because the text inside a heading tag, the style is unaffected. It is overwritten by the inner style.
As a workaround you can add this code:
<style>
#indexHeading1
color: inherit !important;
</style>
this will force the heading to inherit the text color from the parent element.
spoon
Post by spoon » Tue Mar 06, 2018 2:43 pm
Большое спасибо!
