WB12 64 bit
Chris_t
WB12 64 bit
Post by Chris_t » Tue Apr 17, 2018 8:54 am
I took the plunge a couple of weeks ago to use the 64 bit version of the software which appears to be working well with no problems. I see you have just updated WB12. Do you update the 64 bit version with these improvements at the same time or are you waiting until you do a major update to the 64 bit version? If the latter is the case do you plan to update the 64 bit version soon?
Re: WB12 64 bit
Post by Pablo » Tue Apr 17, 2018 9:19 am
The 64bit version has been updated at the same time as the 32bit version.
Chris_t
Re: WB12 64 bit
Post by Chris_t » Tue Apr 17, 2018 12:56 pm
Thanks Pablo. I hadn't checked as at a previous update it looked to me as though it was the same file date. I'll update now :)
