Need advice for creating restaurant menu listing
hobo
Post by hobo » Sun Apr 22, 2018 10:40 am
what would be the best way to create a restaurant menu and price list?
I tried with layers and layout grid but when shrinking browser window the prices end up in the wrong places.
I am sure there must be an easier way??
Re: Need advice for creating restaurant menu listing
Post by Pablo » Sun Apr 22, 2018 12:55 pm
hobo
Post by hobo » Sun Apr 22, 2018 1:28 pm
Do you mean this?
http://www.wysiwygwebbuilder.com/pricingtables.html
Pablo,this might work fine. Have to look around a bit.
I cant seem to find the place to remove all the checkmarks?
I know I cant save it but like to see the visual and if its doable I will purchase.
Do I get instant key?
Post by Pablo » Sun Apr 22, 2018 2:54 pm
You cannot remove the icon, but you can select a different glyph.
hobo
Post by hobo » Sun Apr 22, 2018 2:58 pm
Actually I found feature icon set to check top selection is NONE
I tried different layouts and looks like it is the cats meow.
I'll be right over to get it Pablo
Thanks for that suggestions ....great in BP too.
