Checkbox and Combobox
malls
Post by malls » Mon Apr 23, 2018 12:16 pm
Hi, is it possible both in the Checkbox and combobox hide with events? I need to pick up a div if not selected by the Checkbox.
es:
if checked layoutgrid1 visible with effect
not checked layoutgrid1 hide with effect
if checked layoutgrid2 visible with effect
not checked layoutgrid2 hide with effect
Thank you
Re: Checkbox and Combobox
Post by Pablo » Mon Apr 23, 2018 1:08 pm
Did you check out form conditions?
http://wysiwygwebbuilder.com/conditions.html
malls
Post by malls » Tue Apr 24, 2018 7:41 am
I saw that but it's not for me. I need the condition to hide with effect fer to raise a layout up relative to another.
Thank you.
Post by Pablo » Tue Apr 24, 2018 8:04 am
I'm sorry, it is not clear what you are trying to do. Can you please be more specific?
Did you also try events?
malls
Post by malls » Tue Apr 24, 2018 8:22 am
I just need to make the following condition to hide layoutgrid
if checkbox checked layoutgrid1 visible with effect
if checkbox checked layoutgrid2 visible with effect
condition not available in the checkbox and combobox
sorry for english, i'm italian and i translate via google.
Post by Pablo » Tue Apr 24, 2018 8:49 am
This will require JavaScript.
Either use conditions and then trigger a JavaScript function or use events and call a JavaScript which checks the status of the checkbox.
malls
Post by malls » Tue Apr 24, 2018 8:51 am
is it possible to give me an example?
I will be really grateful.
Post by Pablo » Tue Apr 24, 2018 8:54 am
I'm sorry at the moment I am too busy with other work, for me it may also take a few hours to write the code for this.
