How to install addons
rogerr
Post by rogerr » Tue Apr 24, 2018 6:53 pm
Hello,
I see a number of addons that I would like to try. However, they just download a zip file. How do install them?
Re: How to install addons
Post by BaconFries » Tue Apr 24, 2018 7:02 pm
What addons are you referring to are they WB Extensions you have downloaded? or is it external scripts?
How to manually install zip:
In the Extension Manager select 'Manual install' then select the file.
Or else copy the file to the extensions folder manually.
External scripts you can use the HTML Object. Please note there there is no help with external scripts
HTML Object
Although you can use the Extension Manager to install new extensions it's also possible to copy the files manually to the
My Documents\WYSIWYG Web Builder\system\extensions\folder
rogerr
Post by rogerr » Tue Apr 24, 2018 7:24 pm
Thanks for the tips. I'm going through the page: Free extras/add-ons/plug-ins for WYSIWYG Web Builder 12.
There are different categories, addons, extensions, plugins, etc. Is there a different process for each or can I use the extension manager for any of them? One example I would like to try are the extra blocks.
Thanks,
Roger
Post by Pablo » Tue Apr 24, 2018 8:25 pm
To add extra blocks please see:
http://wysiwygwebbuilder.com/blocks.html
rogerr
Post by rogerr » Tue Apr 24, 2018 11:34 pm
Thanks for the link. The zip file contains a number of jpegs in addition to the wbl files, where should they be copied, to the blocks folder also?
Post by Pablo » Wed Apr 25, 2018 5:39 am
Yes, the jpg files should be copied to the same folder.
rogerr
Post by rogerr » Wed Apr 25, 2018 4:02 pm
Thanks much for the great support!
