Inline frame only works in preview
uli
Post by uli » Wed May 16, 2018 8:09 am
Hello Pablo,
i would like to use an inline frame, which perfectly works in the preview.
But when i upload the published project to my webspace it doesn't show anymore.
Here is the link to the project: https://ufile.io/paps9
Do you have any hints?
Best regards
Re: Inline frame only works in preview
Post by [RZ] » Wed May 16, 2018 8:27 am
have you uploaded the entire site with all of its files?
uli
Post by uli » Wed May 16, 2018 8:40 am
Yes, i uploaded all the files from the "Local Publish" folder.
(index.css, index.html, InlineFrame.css, jquery-1.12.4.min.js)
Post by [RZ] » Wed May 16, 2018 8:46 am
i did a test without problems
both in local mode (preview) and published
perhaps will be useful if you publish to a test area of your server and provide a link to see what the issue is
Post by Pablo » Wed May 16, 2018 8:56 am
Please make sure that you publish all file, including the content page of the inline frame.
uli
Post by uli » Wed May 16, 2018 9:01 am
Here is the link, the four files are in the folder:
https://bit.ly/2Krb1pB
The content page is a link to another server, so i can't publish these files. But as it works in the preview this should'nt be a problem!?
Post by [RZ] » Wed May 16, 2018 9:04 am
the issue is simple:
you are calling from a secured content (https) via an inlineframe a non secured content (http)
hence, the security of your browser may be compromised by the non secured content
browsers restrict the access to a non secured content from a secured page
from http to https -> ok
from http to http -> ok
from https to https -> ok
from https to http -> nope!
uli
Post by uli » Wed May 16, 2018 9:15 am
:roll:
I didn't think of that! Of course that is the issue and i will change the content page to https, so there shouldn't be any more problems.
Thank you very much!!!
Post by [RZ] » Wed May 16, 2018 9:16 am
you are welcome :)
