Is it possible with the 3d Carousel
RiaanN
Post by RiaanN » Thu May 31, 2018 8:18 pm
Hi Pablo
I love the 3D carousel but I dont necessarily want it at the top of the page. I want to have a full screen landing page and have the 3D carousel below that. Is there a way to do that, because no matter what I tried so far seems to work. In the work area I have it inside a full width floating layer, but in preview it jumps up on top of my full screen landing page image.
Regards
Riaan
Re: Is it possible with the 3d Carousel
Post by Pablo » Thu May 31, 2018 8:24 pm
In the tutorial the Carousel is also not at the top of the page. It is below the header.
However, full page is only possible if the layout is flexible/floating. The script in the tutorial was not designed to be used that way.
RiaanN
Post by RiaanN » Thu May 31, 2018 8:31 pm
Thanx for the reply
For argument sake - Lets say I take the candy template. If I understand you correctly I will be able to put the carousel in one of the middle / bottom layers and it will work ?
Regards
Post by Pablo » Thu May 31, 2018 8:34 pm
The code in the tutorial was designed for fixed page layout, it may not work with layout grids.
RiaanN
Post by RiaanN » Thu May 31, 2018 8:49 pm
Thanx Pablo
I will keep playing around.
Would you maybe consider this for a later build perhaps the ability to have the 3D carousel where you want to use it, like the currently build in one ?
Regards
Riaan
Post by Pablo » Fri Jun 01, 2018 5:54 am
At the moment I am too busy with other work, but maybe later.
