Iframe Not 100% Width
mlsto
Post by mlsto » Sun Jun 17, 2018 10:32 pm
Hello
Have an iframe on the page but the width is not 100% although it is in the html code.
Also it is not showing responsive as the original page.
The iframe is located here, under the Latest News: https://www.carlosstomer.com/test/
Here is the original page which is responsive: https://www.carlosstomer.com/news/preview.php
How can I get it 100% width and fully responsive
Thank you
Re: Iframe Not 100% Width
Post by BaconFries » Sun Jun 17, 2018 11:21 pm
An inline frame is already responsive, and if content that you place in it is also responsive then it should work. If you wish it to be 100% width then you can place in a layout grid.
Post by Pablo » Mon Jun 18, 2018 5:47 am
The HTML object has a fixed width, probably because you have selected 'use div'.
Please select 'do not use div'
mlsto
Post by mlsto » Mon Jun 18, 2018 1:36 pm
The no div worked, thank you.
Is there a way I can have the height fit as the page expands? I put height as 100% in the script but the height stays as the height of the html object.
Thank you
Post by Pablo » Mon Jun 18, 2018 2:08 pm
If use select 'do not use div' then the height should not be included, because in that case there is no container.
mlsto
Post by mlsto » Tue Jun 19, 2018 11:36 am
Removed the height but still showed as the height of the html object
This is the code I have
<iframe src="https://www.carlosstomer.com:443/news/preview.php" width="100%" height="700px" frameborder="0" scrolling="auto"></iframe>
Post by Pablo » Tue Jun 19, 2018 11:58 am
Didn't you add this height yourself?
height="700px"
mlsto
Post by mlsto » Tue Jun 19, 2018 1:26 pm
This is the height that is part of the iframe code.
If I remove it or put it as height="" it uses the html object height.
Post by Pablo » Tue Jun 19, 2018 1:44 pm
I'm sorry, but then it is unclear to me what the problem is.
What would you like to do?
mlsto
Post by mlsto » Tue Jun 19, 2018 2:25 pm
I would like the height to extend automatically, right now it is not.
Thank you
Post by Pablo » Tue Jun 19, 2018 2:32 pm
I think that is only possible with script.
mlsto
Post by mlsto » Tue Jun 19, 2018 2:50 pm
Which script?
Post by Pablo » Tue Jun 19, 2018 3:14 pm
A script that you will need to implement yourself.
For example:
https://stackoverflow.com/questions/997 ... hout-using
