I have purchased a font (Have Hearts 1) and installed it on my PC to be able to see the effect it creates in the project. However it slows down the design area quite a bit. Scroll up and down is slow and the toolbox and Blocks windows are in slow motion on opening as well as going back to the auto hide position.
Is fonts and (font size) known for having that effect on WB, or do you suspect something else.
WB14 (32)
Font vs Design Speed
Re: Font vs Design Speed
I am not aware of problems with fonts. Fonts (and rendering) is standard Windows functionality.
However, some fonts can be very big, so that may affect the performance depending on how you use them.
