background mode image not saved in the project folder - a bug
longman
Post by longman » Mon Jul 16, 2018 3:40 am
Hi guys,
While moving my project to a different folder, I noticed the pattern (image) file that i had used for my flexgrid, it was not saved in th project's own generated folder. All other images of the project was in the folder, except background mode image.
i believe this is a bug.
Thanks!
Re: background mode image not saved in the project folder - a bug
Post by Pablo » Mon Jul 16, 2018 6:31 am
How do I reproduce this behavior?
longman
Post by longman » Mon Jul 16, 2018 4:01 pm
The image added in the background here http://prntscr.com/k74h0y, when save the project, the image is not then added to the project folder, when you save the project.
Post by Pablo » Mon Jul 16, 2018 5:05 pm
Ok, thanks. I will investigate if this functionality can be added in a future update.
